This is my Sister's 2005 Pontiac Sunfire (2.2L Ecotec 140HP)
Oil Use Interval: 4,394 Miles
Oil Type & Grade: Pennzoil 5w30
Makeup Oil Added: 0 qts.
Miles on Car: 41,496
Sample Date: 1/22/07
Comments from Blackstone: Paul, looks like your sister has been taking good care of her Sunfire. The universal averages column shows typical wear from this type of engine after 4400 miles on the oil. This oil was run just about that same interval, and wear generally read lower than averages. Insolubles (oil oxidation due to heat, use and blow-by) were quite low at .1%, showing excellent oil filtration and complete combustion. The trace of fuel is just from city driving, around *******, to work and back, etc. Looks like a nice engine and good maintenance. She could run the oil 5000 miles.
Aluminum---2(2)
Chromium---1(0)
Iron-------8(11)
Copper-----3(2)
Lead-------0(0)
Tin--------1(1)
Molybdenum-42(62)
Nickel-----1(0)
Silver-----0(0)
Titanium---0(0)
Potassium--1(1)
Boron------2(37)
Silicon----2(4)
Calcium----2153(2227)
Magnesium--59(146)
Phosphorus-652(738)
Zinc-------732(858)
Barium-----0(0)
Sus Viscosity 210F - 56.8 (56 to 62)
Flashpoint in F - 355 (greater than 365)
Fuel Percentage - .5 (less than 2.0)
Water Percentage - 0.0 (less than .1)
Insolubles Percentage - .1 (less than .7)
Aluminum---2(2)
Chromium---1(0)
Iron-------8(11)
Copper-----3(2)
Lead-------0(0)
Tin--------1(1)
Molybdenum-42(62)
Nickel-----1(0)
Silver-----0(0)
Titanium---0(0)
Potassium--1(1)
Boron------2(37)
Silicon----2(4)
Magnesium--59(146)
Phosphorus-652(738)
Zinc-------732(858)
Barium-----0(0)
