I'm looking at the purchase of one of three LH sedans which are having transmission issues and I'm taking the gamble that one of them needs MINOR work as opposed to an entire rebuild.
The first car is a 1994 Concorde with 172,000 miles and the owner states that 1st gear is the only working gear. Reverse doesn't even work. Car is happiest under 10mph but owner is still driving it wide open to work and back. This car is down to $350 and after the above details were released to me, I don't want it anymore. However if it gets cheap enough I may consider buying it for parts.
The second car is a 1996 Intrepid with 155,000 miles. The owner says it has transmission problems as second and reverse are the only working gears but first works when it is cold. So it's in limp mode. Could need an ATF+4 fluid flush, a solenoid pack, or speed sensors, or one of the cheap easy fixes on AllPar. Car is $300 down from $500 and the seller is not returning my emails but keeps reposting it for sale every day on CL. I'm thinking this is my best bet.
The third car is a 1997 Intrepid coming for sale at an abandoned car auction. The only reason I know it needs transmission work is because I looked up the license plate on PublicData and contacted the owner. He says he abandoned it for a flat tire but that it would not shift into fourth and shifted late into third, as if it was in "3" instead of "D", so he didn't bother going back for it. I estimate it will sell for $300-$400 at auction a week from Wednesday. He says he will give me the keys for it if I come pick them up from him after winning the car, that saves me $50-$75 for a locksmith to come cut one. Owner says he thinks the car has 194,000 miles. I'm thinking the shift linkage needs adjustment.
So I'm voting for the 1996 Intrepid for $300. I know I can drive it home, and I'd already have it if the seller would answer his darned emails. Second choice would be the 1997 Intrepid, but only if I can buy it for cheap, knowing that it darn well could have some issues other than the mentioned tire and a shifter adjustment.
