not to happy about the coolant problem w/this
Quote:
... or you can buy the GM Coolant tabs to help alleviate the problem.
... or you can change your oil every 2-3K with the cheapest SM/GF-4 oil you can find on sale.
Quote:
I've been going in circles w/my extended warranty company about this. they wont cover the repair so I said if the engine blows up you'll cover it, they said no you already know you have a problem. I told them they were missing the point. IF I didn't do the analysis and it blew up.puzzled and not to sure what to tell me as its not on their cue card he referred me to another # to call. haven't done that yet. there is a known lower intake manifold problem on these engines from 96-up seems to have to do w/gasket material not liking DEX stuff. cost of the job is $300-$600 depending where you go.going to inquire at the stealership this week.
Quote:
When you repair this engine, do a little research on gaskets. Felpro has a gasket that is designed better than the GM replacement. It costs significantly more than the other gaskets, but when installed correctly is said to be a permanent fix.
Given that labor is the lion's share of the cost of this repair, saving a few dollars on lower intake manifold gaskets is real folly.
I had my LIM gaskets repaired with the felpro's on my previous 5.7L gm engine (your 4.3 is 3/4 of this engine and shares the same LIM issues) and it was still not leaking after 2 years 30k miles. UOA's proved this.
