The JASO T-904:2006 standards have broken the frictional charactoristics down into three differnt catagories now.
MA1, MA2, and MB.
I don't think anyone can find anything that would support the notion that MB rated fluids are not acceptable for wet clutch use. If so, just where can I find that paper or test standard that states that MB is not acceptable for wet clutch use?
In all three tests for frictional charactoristics, there is very little difference in the numbers, and more than likely the differences could never be realised by the rider.
In fact, the fluid could well be within the MA1 range on two of the three tests*, yet just fall into the MB range on one of them...and the fluid must then be rated MB.
The JASO standards are a guide, but a meager guide at best.
*( STI stop time index, DFI dynamic friction index, SFI static friction index)
A guy I know runs the parts dept of a large Honda dealership. He tried to run the "moly means death" speil on me once, and after a long conversation the guy finally admitted that he was actually clueless on these issues and was only parroting what he had been told to say.
He also admitted to me that he had confused the Honda oils up and had been using the MB rated Honda fluid for about a year in his XR650 w/wet clutch. He stated that when he realized he was using the wrong rated fluid, he was confused because the MB fluid was doing a great job and he never once noticed any sort of clutch degredation whatsoever.
Until the general public understands that "moly" is simply a generic term and is not indicative of what is actually in the fluid, there will always be confusion on this issue. Especially when self proclaimed experts keep trumpeting the dangers or using oils with "moly" in them...which of course means they are "friction modified" and are death to the wet clutch. (major eyeroll)
Of course we can always depend on the marketing speil we get from those with sales agendas....(another major eyeroll)
