2015 Silverado - Put some chrome
by Realtech214
05/02/16 10:22 PM
Ticks!
by spasm3
05/02/16 09:54 PM
shop didn't replace clamps on steering rack
by motor_oil_madman
05/02/16 09:46 PM
First SSD on Xubuntu 16.04
by Eric Smith
05/02/16 09:20 PM
Purolator Boss PBL25277
by Quattro Pete
05/02/16 09:11 PM
Pan w/ drain plug for 62TE
by JTK
05/02/16 09:04 PM
2007 Explorer 4.0 upper and lower intake gaskets.
by ls1mike
05/02/16 08:55 PM
Cars... where they belong: On the road!!!
by Spillips
05/02/16 08:29 PM
I got 'spoofed' !
by Geauxtiger
05/02/16 07:57 PM
2013 Camry DIY Brake Fluid Replacement Experience
by windeye
05/02/16 07:26 PM
Pics Husky 525LS ran on XP oil
by Buzzsaw
05/02/16 07:09 PM
Brake Pad and Rotor opinions
by oilstudent24
05/02/16 07:02 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
22 registered (Farmer, 01_celica_gt, ajchien, carlprop, Atesz792, Dykkerdahl, 1 invisible), 631 Guests and 320 Spiders online.
57779 Members
66 Forums
248388 Topics
#840134 - 02/21/07 09:09 PM Torpedo heater on WVO
crackerloco Offline
Loc: Detroit, MI
I currently use a 100K BTU ReddyHeater to heat my garage. Kerosene is $3-4 a gallon around here, and I really don't want to run #2 diesel inside the garage as I'd have to vent it more and it wouldn't be much cheaper than kerosene. I've heard that a cheap way to run one of these heaters on WVO is to heat up filtered oil on a hotplate, and stick the intake hose into the pan. Has anyone had any experience with this? I know good filtration is essential, and I have access to about 50 gallons/week of WVO so if I can get this setup to work it would save me about $60/month.
#840135 - 02/22/07 01:49 AM Re: Torpedo heater on WVO [Re: crackerloco]
Shaman Offline
Loc: Frankfort, Kentucky
I would check out the biodiesel.infopop.cc first. There is also a forum that does what you are saying, I think the name is something like biofuel for heating or something. Sorry, but the name escapes me.
It will take a good amount of work to get the WVO to runnable product. I donít know about the setup on the heater, but you need to get the junk and the water out for vehicles. Heaters may be different, I donít know.
Also, just found this in a link on infopop.
http://greasecar.com/forum_topicview.cfm?frmtopicID=324
Edited by Shaman (02/22/07 02:32 AM)
#840136 - 02/22/07 09:11 AM Re: Torpedo heater on WVO [Re: Shaman]
Shaman Offline
Did some reading since I donít have any classes today. The important things that I found out are whether or not you have spark plug ignition or glow plug ignition. Also, it seems a lot of people are blending kerosene and WVO without many modifications, but when you try to run all WVO, you need to block flow of air in the back, heat the fuel with something, either a pot warmer, or some people have rigged the fuel hose to stick into the fire stream to preheat the fuel. I found the biodiesel/WVO/WMO for heating subforum on infopop and did some poking around.
Bio for heating
It looks like running 100% WVO will take some work. Read up and let me know what you decide.
Found the altfuels for home heating yahoo group
Altfuel
#840137 - 02/23/07 04:01 AM Re: Torpedo heater on WVO [Re: Shaman]
tom slick Offline
Loc: Central Coast, Calif.
I would be a little afraid of carbon monoxide from an improper mixture by messing with the fuel source.
