Mori, I find it interesting that the Permatex grease has petroleum products in it since the current brake "bible" says petroleum should be kept far away from brake components.
On my recent brake job, I fell for the following new propaganda: Not to use glue type anti-squeel products:
http://www.salemboysauto.com/salem-faqs/default.asp?Action=Q&ID=67
"Extensive testing has proven that what you want is a movement of the pad...to release the dynamic stress that builds in the friction material. When deceleration occurs and stick_slip generates that deadly harmonic energy, it must be dissipated and unfortunately there are only two paths for it to go. One is back through the rotor (that is why you must put a solid based lubricant on the spindle faces before reinstalling the rotor) and the other is, out through the back of the pad. If you glue it down you actually turns it into a magnet (higher density) for the energy to collect in, where as if it is loose an free it becomes more like a piece of wood in nature and hat dull, dead, dampening object has a harder time holding the frequency it is flooded with.
One area I am especially interest in having you consider, is your use of the "glue" type product on the back of the brake pads. I know you alluded to your preference to glue over grease but I wanted to mention that all European and now most every American brake manufacture (Raybestos, Wagner, Bendix, Autospecialty, Qualitee, Performance Friction, etc, etc, etc) frown on a glue type product for pad backs. What they do specify is moly based synthetic lubricant that allow the pad to move freely, wear evenly and also dissipate heat and energy properly. (See our original OE Approved Pastelub 2400ºF Synthetic "Dry-Film" Brake Lubricant on our website,
www.gwrauto.com.)"
I have tons of other information if anyone is interested. Bendix has a new brake lube product out called Ceram Lube.
It seems that a good way to do things is to use a high temp sythetic grease for the pins/bushings and a high solids moly paste for the components exposed to the weather.
On the other hand, people have been getting away with Sil-Glyde and anti-seize on brake for years, so who knows???
