PP HM at Walmart
by dlundblad
07/01/16 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
07/01/16 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
07/01/16 03:29 AM
Old Toyota
by artbuc
07/01/16 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
07/01/16 03:03 AM
Little different lube regimen on my 454
by Alex_V
07/01/16 03:00 AM
REPCO oil sale this weekend in Australia
by SR5
07/01/16 02:58 AM
ALG Go-Juice
by Ws6
07/01/16 02:55 AM
Stupid ? 20hp Intek b&s
by southernjeeper
07/01/16 02:23 AM
Mouse Guns
by bobbob
07/01/16 02:14 AM
Grease for gun
by DARKSCOPE001
07/01/16 01:44 AM
Walmart ST Full Synthetic 5W30 & 10W30 5QT $12.00
by Jonny5alive
07/01/16 01:11 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
25 registered (1foxracing, Astro14, Charlie2015, 2015_PSD, bourne, bigdreama, 2 invisible), 826 Guests and 7 Spiders online.
58332 Members
66 Forums
251078 Topics
Page 1 of 2 1 2 >
#836695 - 02/17/07 08:26 AM Synchromesh Salad Oil Shearback
richard612 Offline
Loc: SoCal
Hi all... I have a 2005 Jeep Wrangler with the Mercedes NSG370 six-speed. I drained the factory mystery fluid at around 10k miles and replaced it with Pennzoil's Synchromesh (MS-9224) fluid per the Chrysler TSB. It's been great for a year and the shift quality has been somewhat improved over the factory fill.
Lately, I've been having trouble with a nasty input shaft rattle when idling in neutral with the clutch not depressed. It only happens under certain conditions: Almost but not fully warmed-up. The roughness of the engine would seem to "excite" the lash in the front-end of the gearbox and it would rattle as if there was a loose bolt hanging out of the flywheel.
I had no idea what was going on with the trans but I do recall the OEM fluid appearing thicker than the 9cSt Synchromesh fluid. I had a hunch that the fluid had sheared-back quite a bit over the last year and become so thin that it couldn't dampen the internals properly.
Acting on this hunch, I drained the Synchromesh and it was pretty nasty. Greyish, with lots of black #@$%! on the drain-plug. I refilled the trans with an everyday 10W-30 and went for a spin tonight. The rattle is about 50% of it's former volume and the trans is smoother and quieter overall. Less whirring when rolling along in 1st with the clutch pushed, and less clunking and banging as the driveline lash is taken-up when transitioning from coast to drive. Amazingly, the syncho action is fine and so is the shift quality. It's a little balky going into 1st and 2nd when cold but this smooths-out very quickly.
Thinking about this transmission and its traditional applications (selected Mercedes C-class, non-US M-class/E-class, Vito minivan, and Sprinter), I'm confident that Mercedes-Benz would never spec a 9cSt fluid for this trans. It's simply too darn loud and clunkety when filled with salad oil!
With all this in mind, I need to get this generic 10W-30 API SL out of there and replace it with a lube possessing an additive package that's appropriate for an MTX. I'd also like to thicken it up just a little bit more to hopefully suppress the last of that input shaft rattle. This 10W-30 is 10cSt versus the 9cSt of the MS-9224 sauce. I'm thinking that a 50/50 blend of MT90 and MTL would yield a 12.5cSt fluid with a strong EP package.
Any suggestions?
2014 V6 Mustang 6M
#836696 - 02/17/07 09:34 AM Re: Synchromesh Salad Oil Shearback [Re: richard612]
Big Jim Offline
Loc: Thousand Oaks, CA
If you had sludge with Pennzoil, you won't like RedLine MTL.
I do believe that you want a synthetic so look for Torco or Royal Purple. They don't seem to sludge up.
#836697 - 02/17/07 03:04 PM Re: Synchromesh Salad Oil Shearback [Re: Big Jim]
richard612 Offline
Loc: SoCal
After some searching, it seems that many people are running straight MT90 in this gearbox with good results. Apparently this unit is OK with a 15cSt fluid.
2014 V6 Mustang 6M
#836698 - 02/17/07 05:36 PM Re: Synchromesh Salad Oil Shearback [Re: richard612]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I agree that some conventional MTF's shear rather rapidly. But lots of black iron in a MT? Yikes!
I would do a 50/50 mix of MTG/MTF. OR in OC go with MTG straight it has a 100C vis of about 14.5 cSt.
#836699 - 02/17/07 06:03 PM Re: Synchromesh Salad Oil Shearback [Re: Pablo]
Greaser Offline
Loc: Windsor,Ontario
Don't mess with it!Put Amsoil MTF and live with it.I have over 100,000 miles on my TJ and when I bought it new it had the "marbles" rolling around in neutral since day one.The NV3550 that I have,which is the same tranny in full size Chev trucks, but different than your six speed.The noise is the same.I'll post a link that has a ggod read on the subject.All in all my noise is almost non-exsistant now and the tranny shifts fantastic but the dealer band-aid fixes do more harm than good.The Amsoil MTF fluis is by-far the best fluis for this tranny...I tried em' all.
1999 Jeep Cherokee-
2001 Jeep Wrangler- both engines 4.0L & Rotella T5/T6 with Napa Gold Filters
#836700 - 02/17/07 06:05 PM Re: Synchromesh Salad Oil Shearback [Re: Greaser]
Greaser Offline
1999 Jeep Cherokee-
#836701 - 02/17/07 06:08 PM Re: Synchromesh Salad Oil Shearback [Re: Greaser]
Greaser Offline
Geez I better start wearing my glasses when posting...spelling
1999 Jeep Cherokee-
#836702 - 02/17/07 08:29 PM Re: Synchromesh Salad Oil Shearback [Re: Greaser]
unDummy Offline
Loc: RI
Depending on the weather(noticed the location), you could probably go thicker without creating the "too difficult to shift when cold" issue that many complain about in manuals.
1st option is just to stick with the Synchromesh. Its a pretty good MTF, not overpriced at local autoparts stores, and cheap enough to change out yearly. And, if you want to thicken it a little, add 10-25% Lucasoil regular or synthetic oil snot.
I myself prefer the straight fills. Redline MTL, Amsoil MTF, and Torco MTF-R are some substitutes.
You can probably step up to a 75w85 but I wouldn't go too thick simply because too many people complain about shift effort. Those 50:50 blends of Redline MTL/MT90, Amsoil MTF/MTG, or RoyalPurple Synchromax/Maxgear are something to consider. And, by looking at the spec sheets, you could probably go 25:75, 33:66, 66:33, or 75:25 ratio depending on the shift feel.
There a some OEM fills in 75w85 available from local dealers like Nissan, Subaru, Mitsubishi, Hyundai.... that can be considered.
Another option if the precisioncrafted Hondacura manual tranny fluid that Idemitsu is whipping up for Honda.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#836703 - 02/18/07 01:11 AM Re: Synchromesh Salad Oil Shearback [Re: unDummy]
richard612 Offline
Loc: SoCal
Thanks for the input guys. That JeepsUnlimited link is interesting. I don't know if there's a real problem here or just a bad choice of lubricants.
I did a little more research and it turns out that Castrol Syntorq 75W-85 is available in the US under Chrysler p/n 4637579 -- it's for the NV4500's and it's a 12cSt fluid. I think it'll give it a go. "Hey, the parts counter guy told me it was the right stuff -- Now can I get my warranty rebuild?"
2014 V6 Mustang 6M
#836704 - 02/18/07 02:41 AM Re: Synchromesh Salad Oil Shearback [Re: richard612]
Anonymous
Unregistered
Couple thoughts...
I have a NV5600, but had the exact syptoms you decribe...it was the clutch disc. It sounded like marbles rolling around in the tranny that went away when I depressed the clutch. They had a TSB on the 2003 dodge rams for that, and it is slowly coming back. I attribute it to the springs in the clutch hub getting loose and allowing the hole assembly to shake...
Another thing is that a lot of NV5600 owners ran 5w30 synthetic oils (Amsoil comes to mind) with good results...this was before you could buy a aftermarket synchromesh-rated fluid like RL MTL, Amsoil MTL, or Royal Purple Synchromax...
However, I drained my original fill of dodge's Synchromesh at 50k and it was still clean. The PZ I replaced it with made it another 25k and was crystal clear when I drained it...you might have an internal trans problem...if the metal on the mag was excessive. Another possibilty is the PZ has literally cleaned all the deposits in your trans...I would wait to see what the next fill drains like before I get too excited...
steved
#836705 - 02/18/07 03:42 AM Re: Synchromesh Salad Oil Shearback
richard612 Offline
Loc: SoCal
Thanks Steve. I'll drain the 10w30 sometime this week. I'll run the NV4500 stuff for 10k then reassess the drain plug glop and the fluid color. I suppose I could do a UOA but I don't have a baseline for this gearbox so I don't know that it would tell me much.
2014 V6 Mustang 6M
#836706 - 02/18/07 03:49 AM Re: Synchromesh Salad Oil Shearback [Re: richard612]
WTJackalope Offline
Loc: Odessa, TX
I had similar issues in an 03 NV3500. Changed twice with PZ Synchomesh, but it would fade very quickly. Then changed to the Amsoil Synchomesh and it is still silky smooth over a year later. I would highly recommend that you try the Amsoil.
#836707 - 02/18/07 03:59 AM Re: Synchromesh Salad Oil Shearback [Re: WTJackalope]
richard612 Offline
Loc: SoCal
I've heard from quite a few people, even those using it "off-spec," that PZ Synchromesh is fantastic initially but goes down pretty quick.
2014 V6 Mustang 6M
#836708 - 02/18/07 04:02 AM Re: Synchromesh Salad Oil Shearback [Re: richard612]
wileyE Offline
Loc: Kitsap, WA
richard, quad4x4 has the syntorq in 2 qt bottles if you wanted to mail order, quite a bit less the the dodge dealer here. GM alsos sells it under it's own part#.
#836709 - 02/18/07 06:50 PM Re: Synchromesh Salad Oil Shearback [Re: richard612]
Anonymous
Unregistered
It does...starts out really nice and (in my NV5600) goes to average in under 500 miles...
The Amsoil stuff seems to be the best (in my NV5600) to date, but even it is slowly falling in shifting performance at just over 10k miles...I am awaiting bottles from Blackstone to check both my engine oil and the Amsoil MTL to see what is going on...
steved
Page 1 of 2 1 2 >
