I found some quote/unquote green the other day M04 code I believe.
Here is a pic
Looks more like Brown GC to me.
Then I said some magic words
"entstehen grüne Elfe" and voila:
It really is some pretty ugly stuff under normal halogen house lights, it has a green tinge, mostly brownish as opposed to gold.
But when you hit it with the flash - it is definitely green.
I guessed that something in the oil only reflects the green spectrum 180 degrees (i.e. back in the direction of the light source) as opposed to something that is green when u shine light through it.
So I tested that "theory"
same light source used (not a flash) coming from the back, then front. Actually the closer you get to 180 degrees, the "greener" it gets.
Interesting. But wait until you see this.
I said the magic words 3 times really fast and this happened
entstehen grüne Elfe, entstehen grüne Elfe, entstehen grüne Elfe
Maybe we should call it Multichromatic Castrol
Here is a pic
