A gear oil and a motor oil are both 8.5 cSt at 100C. The motor oil is graded SAE 20, but the gear oil is graded SAE 80. Am I correct to understand that the discrepency is due to the grade applied to the gear oil being figured when the gear oil is at 150F (65.5C) and thus shows a much higer cSt, say 100 or so at that lower temperature? I assume that came about because gear oil does not run as hot as engine oil.
