After the beating that we just took (14" of snow and 40-45 mph winds), my snowblower has run more in the last 48 hours, than I think it has run in the previous 5 years combined that I've owned it. And this was all hard use...the snow was between 1'-2' (a few areas were 3') deep everywhere, running at near or full throttle.
Yesterday, it had run several hours non-stop in one stretch (I left it idling on the trailer between jobs, so it wouldn't freeze up). After all was done, I noticed that the oil was actually turning dark.
Changed the oil last night in anticipation of the next forecast of snowfall (which is this weekend, unfortunately).
Instead of its normal oil, I bought a quart of SuperTech Syn 5w-30 for it. At $2.97 a quart, it was hard to set it back down on the shelf. (Especially when yellow bottle Pennzoil is only .50 a quart less).
One thing that I don't understand, is that Tecumseh actually states that straight SAE 10 weight oil is one of their recommended oils for -20 to +40 f. Maybe my way of thinking is off, but I'd have a hard time in using straight 10 weight in any engine. I've only used it before as a hydraulic fluid.
Curious to see how it goes. I've seen some UOA's for SuperTech syn that look really good. I know that this is far from being a high tech application, but for 50 cents more, why not? If nothing else, it should start easier.
BTW... Snowblower is a 22" dual stage MTD with a 5hp Techumseh Snow King engine.
