Anybody have any good information on the engines the Toyota teams are running in NASCAR this year?
Quote:
Here's some older info:
http://www.popsci.com/popsci/automotivetech/03a91196aeb84010vgnvcm1000004eecbccdrcrd.html
Looks like they used the Craftsman Truck Series engine as a starting base.
Quote:
This forced the team at Toyota Racing Development (TRD) -- one of the largest racing operations in North America but a Nascar virgin -- to start from scratch.
"We told them to take a look around at the engines in the garage," Nascar R&D director Gary Nelson says. "We said, ?We're not going to tell you what valve angle to use, for example. But go smaller than the largest and larger than the smallest.'" In other words, no thinking outside the box.
Trouble is, nobody knew the precise dimensions of that box. "So we had to reverse engineer the Chevy, Ford and Dodge engines," says Lee White, general manager of TRD. "We measured 3,000 block castings and 2,000 cylinder head castings for each one -- 15,000 total."
The TRD team set out to incorporate the best features of each engine, while hunting for Nascar-legal design tweaks.
Quote:
I've never understood the NASCAR thing. Pushrods and carburetors in their brand new high tech racing engine?
You probably never will. What is low tech about carbs and pushrods.Quote:
Quote:
It's certainly high tech.
BTW, I saw my first Offy in the flesh the other day. What's high tech about OHC, pentroof chambers etc ?
Quote:
Think metallurgical, mechanical and manufacturing technology to advance the pushrod design to where it is today.
Quote:
BTW, pushrod V engines take up a lot less space than OHC V engines, so can be better packaged into a typical street car . They are still valid and manufactured.
Quote:
OK, so I have a new appreciation for the pushrod. I just might check out a race one time when they run on a real track. You know, the kind with both kinds of turns.
