HeavyAssault - info on AMSOIL products for your truck can be found at
http://www.amsoil.com/scripts/runisa.dll?amsoiloaf:index .
AMSOIL and your manufacturer suggests the following oil types and choices for your truck:
2006 FORD TRUCKS F350 PICKUP 6.0L 8-cyl Engine Code P TurboDiesel
Engine Oil
Grade 1......CI-4+
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil
Synthetic 5W-40 Premium Diesel Oil
Synthetic SAE 30 Diesel Oil
-23 To 32°F......10W-30[1]
-29 To -1°F......5W-30, 5W-40[2]
-29 To -18°F......0W-30[2]
above -12°F......15W-40[3]
1. Ford TSB 05-16-6 states that SAE 10W-40 is acceptable
to use in operating temperatures from -1 °C (31 °F) to
32 °C (90 °F).SAE 10W-40 is the preferred viscosity if the
operating varies from -20 °C (-4 °F) to -1 °C (31 °F).
2. Ford TSB 05-16-6 states that the shown viscosity is
acceptable to use in the shown temperature range.
3. Ford TSB 05-16-6 states that SAE 15W-40 is acceptable
to use in operating TEMPS from -12 °C (11 °F) to
-1 °C (31 °F). SAE 15W-40 is the preferred viscosity if the
operating is above -1 °C (31 °F).
Suggested oil change intervals for AMSOIL products can be found at
http://www.amsoil.com/lit/g1490.pdf .
So if you are looking for an AMSOIL product to go 25,000 normal miles or 15,000 mile severe miles up to 1 year, then your AMSOIL recommended choices are the 5W30, 15W40 and the SAE 30.
Hope this helps.
