Quote:
At what mileage did your lower i/m gasket start leaking and do you have any tips as I am going to replace mine as soon as it warms up a bit. Also, how does the 3.1 run with the 40 weight oil. Did you ever do a UOA with it? I may run 15/40 in the summer if I thought it was a good combo.
I bought the car about a year ago from a fleet auction at the local state college- it had 159K miles on it. The lower intake manifold (LIM) gasket was leaking a bit externaly, and I've owned two of these engines before- so I bought it with the understanding that I might as well go ahead and change the gasket. Here's a thread of mine on another site that gives all the gory details.
http://60degreev6.com/showthread.php?t=32325&highlight=intake+gasket
It might be a good idea to post on that thread if you have detailed questions. Lots of good info on GM 60 degree V6's.
I don't know what year your engine is, but they changed these engines several times over the years- but they're very similar from 1994 and up. My advice and part numbers on the above thread will generally apply to a 1999 (I THINK) and up 3100. There are small differences, and different gasket sets depending on years.
Here's the absolute most important thing I can tell you about that engine: KEEP THEM PUSHRODS IN ORDER!!!!!1@!#@!$. I can't stress this enough. The intake and exhaust pushrods are different lenghts, and if you put the engine back together with two swapped, then it'll run the head and/or a piston as soon as you crank the engine. Folks post all the time on that V6 message board who have just FUBARed their engine this way. Beware...
I've run both 10W30 and 15W40 in my other 3100 engine ('94 Corsica), and I can't tell a bit of difference in how they run. I've never done an oil analysis on either engine (too cheap, too lazy), so I can't give you any hard data. I mainly run 15W40 because I'm a diesel mechanic and often get leftovers for free... and I rationalize this by noting that most heavy duty 15W40's are good quality oils, and thicker is obviously better
But back to the topic at hand. I already have enough dexron 6 for the 4t65E, and this thread has nearly convinced me to go with the same for the 4t60E. Still not much more than speculation and hearsay, though... real data would be nice, but seems scarce at this point.
