If your thermostat is rated for 180 degrees and your truck is seeing lower temps, you might have a bad thermostat. I don't see why you can't stay at 180 in the winter providing your cooling system is working fine and maintains the 180degrees F.
It should hold the rated temp no matter what your temp outside.
I have a 194-202 thermostat. Thats open to fully open. and I see between 197 to 202 max summer or winter.
