Thanks again to everyone!
I just put in an order a little less than $160 for the following:
13711247405 Air Filter
64111393489 Cabin Air/Pollen Filter
11431717666 Dip Stick Tube Seal; O-Ring for Oil Dipstick; 9x2.2mm
RCS12X16 Oil Drain Plug Gasket; Oil drain plug gasket.; Copper Seal Ring 12x16x1.5mm X10
11421432097 Oil Filter Kit X4
25161215780 Shifter Handle Set Screw (A/T); For Automatic Shift Handle
25161216905 Shifter Knob/Handle
51231960852 Shock/Strut, Hood; Left/Right X2
51231908430 Shock/Strut, Hood; Retaining Clip X5
11121721876 Valve Cover Gasket
11121721475 Valve Cover Gasket; Valve Cover Gasket for Spark Plug Holes
11121721476 Valve Cover Gasket; Valve Cover Gasket for Spark Plug Holes X3
11121721879 Valve Cover Grommet Gasket; Valve Cover Bolt Seal X15
36131181079 Wheel Center Cap/Emblem; Emblem for Wheel Center; 70mm Diameter(2-3/4 inch) ; Adhesive Back X2
I will take all coments on the control arms and simply do some 'looking'. Sounds like a suspension system similar to the old SAAB 900s which I am very familiar with. (forgive me if I am off on that, I have yet to even pull of a wheel)
I already note that I need the high side hose on the PS pump. That will be on the next order.
I don't know that I dare ask about .... oil .... All invoices state Valvoline 15w-40, not an easy oil to find.
I see the nods to Delo, which I am willing to pour in ... but, Delo has two flavors ...(orig and LE) ??
When the order arrives, I had planned to pour in Valvoline at least one last time, till I did my homework and got word back from Terry, but if I can't find it, I guess I'm gonna have to go for the gusto and make a switch.
Thanks again!!
