I've been hesitant to post a question in here because I'm sure it's been answered a ton of times before, but I have several questions about oils that allow extended intervals between changes and some other stuff as well...
My first question is, with modern high-quality oils claiming to be safe for 15,000 mile intervals and beyond - is it safe? Would I be causing reliability problems down the road? I know that vehicle reliability is based mostly not on the oil I use but how I drive and how often I change the oil.
Second of all - what oils would have the longest intervals? I read somewhere of a 25,000 mile rated Amsoil synthetic.
Third - I live in a somewhat dusty environment. Should I be concerned about changing my oil more often? I've been using a K&N air filter but I think I'll be removing it because of the high level of particulate matter they let through, and I've been using both Mobil 1 EP with a M1 EP Filter and changing it at 10000 instead of 15000 miles and Royal Purple with a K&N oil filter and also doing it at 10000 miles rather than 12000.
Fourth and final - When it is time for an engine rebuild, what oil should I use to help prevent sludge buildup... I hate cleaning parts
Thanks for any insight you can give.
