How about some info on the engine first? Main, rod, piston clearances, crank journal finishes, piston/ring type and gaps, CR, head mods, valvetrain specifics such as roller/flat, spring pressures, oil pump/cooler mods, etc, etc.
Next some info on the application and current running parameters such as oil pressure/temps under various typical conditions.
And if Nickens is a professional engine builder, why not ask him what he recommends?
