Got me swinging.
It's got no x'ref in Baldwin, Donaldson, Hastings, Fram, or Purolator
filtermart.com has about 8 numbers that puke out of its search engine. There's something wrong with their link to actually get the dimensions.
BUT!!! All of their numbers are extensions of your primary part number. That is, 33247
1 ..all the way up to 33247
9
So, near as I can figure ..they have 9 different offerings in that basic filter.
Now going by the filter thread, Donaldson has some offerings:
P550219
Here's one with a water separator
P558040
SPIN-ON FILTER WATER SEPARATOR/RPLC P558040
Fuel Filter Water Separators Product Attributes
A - OD (Inches): 4.28
B - ID (Inches): 13/16-18
C - Length (Inches): 8.84
D (Inches): 2.83
E (Inches): 2.45
Product Type Description: FUEL/WATER SEPARATOR SPIN-ON
Primary Application: MACK ENGINES
Substitution: P550219 Standard Fuel
This is a Wix ...
Part Number: 33419
UPC Number: 765809334199
Principal Application: Mack Fuel/Water Separator w/Drain
All Applications
Style: Spin-On Fuel/Water Separator Filter
Service: Fuel
Height: 8.689
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 13/16-18
Burst Pressure-PSI: 325
Nominal Micro Rating: 12
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.860 2.500 0.220
The gaskets are slightly different
Part Number: 33357
UPC Number: 765809333574
Principal Application: Case, Consolidated/Cummins Engines (12 Micron)
All Applications
Service: Fuel
Height: 6.081
Outer Diameter Top: 3.710
Burst Pressure-PSI: 315
Gasket Diameters
Attached 2.834 2.462 0.200
Packed 1.046 0.770 0.186
Here
Donaldson
Just put the thread pitch in the SEARCH field on the upper right.
