OK, I have seen a ltte bit on this topic. Enough where I really can't decide yes vs no.
My main hesitation is the issue with paricles left in the bottom of the drain pain. However, shouldn't these have been caught in the filter, or are they too heavy to circulate with the oil? Heck, will these even come out through the drain plug, or should the pan be pulled from time to time and cleaned?
I have seen arguments over whether one method removes more oil than the other (does it really matter if one gets out 8oz more oil)
Any suggestions from the oil nuts here?
