Quote:
Similar to someone just posted great links on cSt measurements, anybody want to post anything on pour points?
There is a difference between pour point and freeze point.
In the pour point test (ASTM D-97), a couple of ounces of oil is placed in a glass cylindrical jar measuring about 1" in diameter and 4" tall. The jar is sealed with a rubber stopper and a thermometer is inserted through the stopper and into the oil with the bulb just below the oil surface. This jar assembly is then cooled at a prescribed rate and the oil is checked every 5°F as it approaches the expected pour point by turning the jar horizontally. If the oil surface moves at all (pours) within 5 seconds, the jar is returned to the cooling bath and to cool another 5°F, and this checking is repeated until it no longer pours. The last temperature at which the oil surface moved is the pour point. (There are some automatic methods being used that differ from this manual method but work on the same principal).
If the oil has no waxes, such as PAOs and esters, the oil remains clear (unless wet) and the pouring stops when the oil is just too thick to pour under it's own weight. If the oil has waxes, freezing may occur, either before or after the pour point is reached.
Freezing occurs when the waxes grow crystal structures that knit together. This crystalline structure usually turns the oil into a white opaque solid (waxy solid as opposed to glass solid) and flowing stops. Sometimes you can see some oil flowing freely behind or within the waxy crystals indicating that the oil would have had a lower pour point had the freezing into crystals not terminated the test. Hence the freeze point is the point at which crystalline structure growth prevents flow (like water turning into ice) as opposed to the oil simply being too thick to flow (pour point).
Petroleum oils have waxes that, depending on how well they are refined, can cause the base oil to freeze at temperatures as high as 0°F or more, well within “normal” temperatures. In reality, however, it doesn’t happen since the finished oils will contain Pour Point Depressants (PPDs) to inhibit the crystal growth and suppress it down to perhaps -40°F, well below “normal” temperatures. Therefore it is unlikely that you will ever encounter a quality motor oil that will freeze on you.
Tom
