My mother owns this car and takes mostly short trips. Whenever I check the oil fill cap area, there are water drops and yellow "mustard-like" sludge buildup on the bottom of the oil fill cap. The entire engine is sludged too. It's on an Auto-RX cleaning phase but the lack of reaching full operating temps still allows this aforementioned buildup to occur in the oil fill area. The oil on the dipstick looks fine, like used motor oil should look like.
So, is this a common problem with these engines or is there maybe a coolant leak into the oil? If there is a coolant leak, are there any simple ways to detect it other than doing a UOA or monitoring the coolant level? Maybe a blotter test would detect coolant in the oil? Thanks.
