I don't have any sealed beam headlights around to compare... Is the three prong connector on those the same dimensions as on the H4 (9003) bulb?
Thanks.
Thanks.
Thanks.
Quote:
No, they are different. The H-4 plug is like this |_| The sealed beam is like this \_/ When I installed H-4s, I broke the three prong plastic connector, separating the wires that already had crimped female blade terminals and plugged them into the male H-4 lamp terminals. If you do it this way you will need to identify the high/low/ground on the wires and lamp terminals.
Quote:
Try again G-Man. I bought these 165MM H-4s from Dan Stern for my Chevy S-10. The plugs on the stock sealed beam plugs do not fit the H-4s. Dan provided me conversion plugs that I did not use. I just plugged the female spades into the connector after I broke the DOT plugs.
Quote:
I thought the sealed beams all had the same type plug whether they were round/square, large/small, etc. if they were Hi/Lo. I do not know if the High Beam only on the four headlamp setup is different like on your Olds. The S-10 uses only two lamps.
The only thing for certain is 165mm sealed beam Hi/Lo male spades are angled different than the H-4 male spades.
