I am on the market for a used car. Does anybody have any experience of volvo s60. The low-pressure turbo I5 seem produce enough power. How is the reliability? Is it easy for service?
Thanks.
Thanks.
Quote:
Just like tune-up, maybe replace the turbo which may fail after 100k miles even carefully maintained. Any DIYer owner of S60 would like to chime in?
Quote:
BTW she still running strong at 346K (64K on new motor) miles on her way to 500K miles.
Quote:
The trend to longer fluid change intervals and "lifetime" fluids is something Volvo has only recently embraced to "keep up with the Joneses", and is contrary to their traditional philosophy. So while Volvo may no longer recommend it, it is probably good practice if you intend to keep the car for many years to change the ATX fluid much more regularly than every 100k.
The fluid used in the later P2s is a 3309-compatible type, and bulk 3309 can be used (and many dealers do use it) as a substitute for the very expensive Volvo bottled synthetic.
Volvo's dominant marketing niche is safety, however, and they will do nothing to tempt sullying that image. I believe Volvo still advocates a two-year brake fluid interval, which leaves most general mechanics drop-jawed.
Regular and comprehensive fluid changes is probably the best thing one can do to go far in Volvo's "high mileage" club.
Quote:
but BMW's also call for a 2 year brake fluid change regardless of mileage.
Oh yeah....and you need the BMW proprietary "Modic" computer to do a brake fluid change. Something about releasing the ABS system (not to mention releasing BMW owners of the ability to have this done at an independent shop).
