OK, lets here it. What would you recommend for use in pre 1916 automobiles that use a non presurized splash/total loss system? This sytem uses holes and dippers in the rod ends for lube and drip holes for splash to flow into holes in the main bearings. I have heard many "stories" about new oils that have removed zinc causing problems.
