I can't figure out why anybody would want to buy an SL or SJ rated motor oil. The SM oils of today are years more advanced. And even locating SL or SJ oils might prove to be difficult. Why would you want these older oils-you think they have more Zinc?
In addition, if you did somewhere in some dusty corner locate some SL or SJ rated oil, the oil would be years old. According to what I read somewhere Pennzoil says that motor oil has a shelf life of about 18 months. Sooner or later the oil is going to go bad, and SL and SJ rated oil is inferior anyway to newer motor oils. If you are worried about Zinc levels you could buy a oil supplement like the Valvoline or Schaeffer's supplements and put additional additive into your oil (I would recommend only a few ounces especially in cold weather).
