I am thinking of using a portable power supply on my Wolverine heat pad to warm up the oil when an AC outlet is not available. According to Wolverine "THE #9.1 DRAWS 1.1 AMPS. ABOUT THE SAME AS A LIGHT BULB.", the model 9.1 uses 120V and is rated 125W.
Will the following Sears product provide adequate power to the heat pad, and how long will it sustain if it is fully charged?
http://www.sears.com/sr/javasr/product.d...O&ihtoken=1
