Equipment Make: VW
Equipment Model: Golf NA 2.0
Oil Use Interval: 10,503
Makeup Oil: None
Oil Type: German Castrol (Gold) 0w30
Miles on Unit: 87,007
Aluminum 3/3/1
Chromium 1/0/0
Iron 14/12/9
Copper 13/9/8
Lead 1/3/2
Tin 1/0/1
Moly 4/54/338
Nickel 1/0/0
Manganese 0/0/0
Silver 0/0/0
Titanium 0/0/0
Potassium 0/0/0
Boron 3/12/23
Silicon 9/10/9
Sodium 7/5/6
Calcium 1903/1821/1608
Magnesium 553/446/7
Phosphors 866/840/624
Zinc 1088/1022/778
Barium 0/0/0
Viscosity SUS @210dF
Should be 59-68
Tested 65.0
Flashpoint
Should be >385
Tested 325
Fuel Dilution
Should be Tested 3.0
No Antifreeze
Insolubles 0.3
BlackStone Comments: Most wear stayed steady in this most recent sample from your Golf. Copper increased, and although it's not cautionary, we will keep an eye on it for you. It's probably a response to your long oil change interval, though it may also be related to the fuel. Last sample we found 2.8%; this time we found 3.0%. This is more than we like to see, though it's possibly from idling or stop-and-go driving. Be
sure to take the engine out on the highway before sampling next time. If fuel is still present, we'll suspect a problem is developing. Check back.
Right column was a run of Chevron Supreme for 4,000 miles. Middle Column was previous run of GC. Left column is current run of GC gold. The car has gone off to college and I see it very rarely, hence the long drain this time. This is why I buy good oil and run short intervals, because someone always “forgets” to say something when it's due for service! At any rate, I'm not really concerned with the fuel, I'm sure the car is idle quite a bit since it's in colder county now, and some of it maybe from me driving from the house down to the garage which takes about 1.5 minuets. I can't complain about the way GC performed here.
Makeup Oil: None
Aluminum 3/3/1
Chromium 1/0/0
Iron 14/12/9
Copper 13/9/8
Lead 1/3/2
Tin 1/0/1
Moly 4/54/338
Nickel 1/0/0
Manganese 0/0/0
Silver 0/0/0
Titanium 0/0/0
Potassium 0/0/0
Boron 3/12/23
Silicon 9/10/9
Sodium 7/5/6
Magnesium 553/446/7
Zinc 1088/1022/778
Barium 0/0/0
Should be 59-68
Tested 65.0
Flashpoint
Should be >385
Tested 325
Fuel Dilution
No Antifreeze
Insolubles 0.3
