Given that you have a 1 um, bypass filter installed, these wear metal concentrations are very troubling. The vis of 67 SUS (approx 12 Cst) shows this 5w-40 sheared badly in this application, which is partially responsible for the elevated bearing wear. The 19 ppm of K may indicate a small coolant leak,which would make this problem worse.
The levels of Fe/Cr/Al indicate dirt ingestion that is causing an increase in upper engine wear. The key here is the 2 ppm of nickel, which can only come from the stainless steel used in the intake/exhaust valves. I'm guessing this engine has some sort of aftermarket intake system on it?
I'd recommend a short run of say 5000 miles using an SAE 15w-40 diesel oil - which should be more resistant to shearing. If you are still seeing abnormal wear, I'd do some serious testing for an internal coolant leak and I'd check all the connections on the intake system for air leaks.
