Quote:
I wouildn't worry about a little varnish. Close it up, keep the oil level topped off and you will never know the differnecey if you cleaned it or not. As long as all the moving parts and oil passageways are unencumbered by the varnish it is little more tahn discoloration of the metal. If it becomes gummy and thick and interferes with anything or is thick enough to act as an insualtor against heat transfer it is a problem. If itnot waht is there to worry about? A clean engine is nice to look at but many here put too much value on shiney new metal clean engines. Telling someone that a thin layer of varnish in a 96 bulk oil serviced vehicle is in need of a "fix" is silly. The best fix for tis Saturn is continued service and not worrying about cosmetics.
