I just bought a 95 Neon and wanted to do a filter and fluid change.Nobody around here carries ATF+3, just ATF+4. I thought I read that ATF+4 is not compatible with the older seals in trannys that used ATF+3? The brands I've found are Valvoline($$$) Mopar($$) Supertech($) Which would be the best if I have to use ATF+4?
