2015 F 150
by BISCUT
22 minutes 16 seconds ago
Ever have an "old guy" day?
by daves87rs
Yesterday at 10:25 PM
Fram Ultra C$11.87 (Ontario)
by dgunay
Yesterday at 10:16 PM
dodge 4.7 fram problem?
by joel95ex
Yesterday at 09:45 PM
ok until oil change 4.7 dodge
by joel95ex
Yesterday at 09:41 PM
0w20 vs 5w20 running on a Mazda 3 2014
by Stewie
Yesterday at 09:37 PM
5w20/30 4.4L Castrol Edge WM Canada $24.88
by Stewie
Yesterday at 09:31 PM
Back to greasing stuff...
by JHZR2
Yesterday at 09:04 PM
Castrol Import Multi question
by Carguy21
Yesterday at 08:20 PM
2005 F150 steering rack
by Colt45ws
Yesterday at 08:12 PM
Tinkering around today with my Cold Air Intake
by GumbyJarvis
Yesterday at 07:51 PM
Crude Oil at Historic Lows and 5W30 is High Priced
by cjcride
Yesterday at 07:35 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
20 registered (chrisri, CELICA_XX, BISCUT, 3800Series, Branson304, edhackett, 1 invisible), 601 Guests and 198 Spiders online.
56865 Members
66 Forums
244433 Topics
#786786 - 12/12/06 03:38 PM Anti-Squeal Paste for Brake Pads.
George7941 Offline
Loc: Toronto, Canada
I have seen shops use hi-temp silicone instead of the blue anti-squeal paste. Will the silicone work almost as well? The blue paste looks like silicone anyway, especially the way it sets up.
2006 GMC Sierra 4.3l, NV3500,G80 locker rear, Formula Shell Synthetic 5W30, Wix 51036, Dexcool.
1987 BMW R80
Staying out of the right lane a lot.
#786787 - 12/12/06 04:33 PM Re: Anti-Squeal Paste for Brake Pads. [Re: George7941]
Char Baby Offline
Loc: Western NY
The silicone works very well. It's great for lubing sliders as well as lubing the back of the pads. Absorbs squeel better than the paste IMHO.
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#786788 - 12/12/06 07:07 PM Re: Anti-Squeal Paste for Brake Pads. [Re: Char Baby]
doitmyself Offline
Loc: MI
I think George is refering to Hi-temp silicone caulk/gasket material, not silicone grease.
Here is an interesting OPINION about caliper pad "glue/paste" from this site (brake squeal section):
http://www.salemboysauto.com/salem-faqs/default.asp?Action=Q&ID=67
"Can I polity disagree, #1 about your use of pad glue and #2, you non use of moly grease?
Extensive testing has proven that what you want is a movement of the pad...to release the dynamic stress that builds in the friction material. When deceleration occurs and stick_slip generates that deadly harmonic energy, it must be dissipated and unfortunately there are only two paths for it to go."
"Well you may be asking, what does this do for me? I hope it gives you pause to look into the new technologies that are available to the automotive industry, especially with respects to servicing and maintaining brake systems. One area I am especially interest in having you consider, is your use of the "glue" type product on the back of the brake pads. I know you alluded to your preference to glue over grease but I wanted to mention that all European and now most every American brake manufacture (Raybestos, Wagner, Bendix, Autospecialty, Qualitee, Performance Friction, etc, etc, etc) frown on a glue type product for pad backs. What they do specify is moly based synthetic lubricant that allow the pad to move freely, wear evenly and also dissipate heat and energy properly. (See our original OE Approved Pastelub 2400F Synthetic "Dry-Film" Brake Lubricant on our website, www.gwrauto.com.)"
Just a sales person opinion, mind you. But, my investigation SEEMS to indicate that more people are now using a "lubricant" on the pad packs instead of a glue. I think Honda manual's specify Molykote 77 lube.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#786789 - 12/13/06 03:51 AM Re: Anti-Squeal Paste for Brake Pads. [Re: doitmyself]
alreadygone Offline
Loc: North Arkansas
doitmyself, is far more correct than he knows. Any of the old glue type noise products have been proven disfunctional. Their purpose was never as much to hold the pad in place as it was to create a rubber "cushion" between the pad and caliper components. Problem is, the hydraulic forces exerted in normal braking will cut/press this layer of cushon out in a short time.
To function properly the new synthetic greases must perform two tasks, STAY IN PLACE despite heat and pressure and lubricate contact areas so harmonic noise isn't generated.
We've been using brake grease (don't that sound strange) for several years now and noise comeback is almost nill.
Should be applied to all contact points of pad (EXCEPT ROTOR),caliper piston, caliper, and areas where pads touch mounting bracket.
Bob
To which version of reality would you like to convert me?
Bob
