Why does this site fight me when I try to post anything in columns? Augh. I really wish I could just post HTML and be over with it.
This UOA is really to see what the metals were at and to do a particle count before I put on an oil filter magnet. The only thing that is interesting is that the Viscosity is low. I added 4oz of LC20 at fill and 1 oz at 1500 miles. Not sure if that could have caused it.
Code:
Honda Odyssey
3.5L V-6
Gasoline
Vehicle miles: 7,693
Miles on oil : 2,181
Life of oil : 2 months
Lab: Blackstone
Slowly but surely, your odyssey is progressing past wear-in. Aluminum and
silicon were reading most out of line, and they both dropped again, as did the other metals.
The viscosity read a little low, though we didn’t find any fuel
that would have caused the viscosity shift. We are finding that some Honda
engines tend to cause the viscosity to drop, and it doesn’t seem to hurt
anything. The PC read 16/12, clean for an engine oil. The complete particle
breakdown is attached to the hard copy that is on its way to you. No
contaminants found.
Date 12/06/06 09/28/06 06/26/06
MI on oil 2181 2754 2666 Universal Average
Unit MI 7693 5420 2666
Aluminum 10 11 14 4
Chromium 0 1 1 1
Iron 7 10 20 13
Copper 22 29 81 34
Lead 0 0 1 1
Tin 0 0 0 0
Moly 125 518 345 72
Nickel 0 0 0 0
Manganese 0 1 0 1
Silver 0 0 0 0
Titanium 0 0 0 0
Potassium 2 3 9 1
Boron 152 41 190 49
Silicon 18 30 91 46
Sodium 5 7 14 11
Calcium 2018 1947 1717 2223
Magnesium 7 6 11 63
Phosph 595 589 654 692
Zinc 692 717 782 825
Barium 0 1 4 0
Sub Viscosity @ 210 = 49.3
Should be 52-61
Flashpoint = 375
Should be >355
Fuel % =
Should be
Antifreeze % = 0
Should be 0
Water =
Should be
Insolubles = 0.2
Should be
Code:
Honda Odyssey
3.5L V-6
Gasoline
Lab: Blackstone
contaminants found.
Aluminum 10 11 14 4
Chromium 0 1 1 1
Iron 7 10 20 13
Copper 22 29 81 34
Lead 0 0 1 1
Tin 0 0 0 0
Moly 125 518 345 72
Nickel 0 0 0 0
Manganese 0 1 0 1
Silver 0 0 0 0
Titanium 0 0 0 0
Potassium 2 3 9 1
Boron 152 41 190 49
Silicon 18 30 91 46
Sodium 5 7 14 11
Magnesium 7 6 11 63
Barium 0 1 4 0
Should be 52-61
Flashpoint = 375
Should be >355
Fuel % =
Should be
Antifreeze % = 0
Should be 0
Water =
Should be
Insolubles = 0.2
Should be
