Does a 5 degree slope affect front rear reading? If so, the lower side (elevation) would read higher or lower (pressure), vs. flat?
Quote:
We measured the tire pressures of a vehicle on a lift (tires completely unloaded), and then on the ground, and the pressure increased a maximum of 0.5 psi (we used a very accurate gauge)
I would think a driveway could be as severe as that!
Quote:
Quote:
...I would think a driveway could be as severe as that!...
Only if it was vertical
Did you forget an n't?
