Only 1400 miles on the oil but it's been in the engine since Feb. This is the truck I'm restoring and run it around the block once a week or so.
IMO the fuel is from a leaky injector. Thing runs rough when started untill the injector gets fuel through it.
My readings universal avg
Aluminum-2-5
Iron 4-24
copper2-4
Calcium 3027-2343
magnesium 18-63
silicon-2-5
phos 1032-988
zinc 1147-1109
barium 1-0
sus vis @210F 81.3--69-80
flash-395--410
fuel 1.5
insolubles-.3
Everything else is zero!
I pulled this sample out of the Luberfiner filter on the side of the cab. I Was expecting to find it quite dirty since It came from the dirty side of the filter. Was mainly concerned with coolant in the oil.
A month ago I pulled a loaded trailer to see how well the truck would pull. I really gave it a workout but it didn't seem to hurt anything.
I was a little concerned about the length of time that the oil has been in the truck but I think I can let it go till next Spring.
Not bad for a 44 yr old engine.
Aluminum-2-5
Iron 4-24
copper2-4
Calcium 3027-2343
magnesium 18-63
silicon-2-5
phos 1032-988
zinc 1147-1109
barium 1-0
flash-395--410
fuel 1.5
insolubles-.3
