Hey everyone,
I'll try to make this as brief as possible. When I bought my 2005 Altima 3.5 SE 5-speed m/t brand new, the shifting action definatley left something to be desired. It was very hard to shift in the morning (on a cold start), and would grind from 1-2 and 3-4. I was not able to downshift to 2nd from 3rd unless I double clutched (and even then, it still would grind). The tranny would absolutely not go into 1st unless the car was completely stopped. This behaviour would go away after about 15-20 minutes of driving, but downshifting to 2nd and to 1st was still not perfect and would sometimes grind.
I switched over to Amsoil's GL-4 MTG 75-90, and there was no change in behaviour, although warm shifts did feel a bit better.
Then I drained that out, and tried a mixture of Redline MTL and Redline MT-90 (55% MTL, 45% MT-90 as recommended by Dave at Redline). Immediately, almost all of my problems dissapeared. There was no more grinding at all, at any temperature, downshifting was beautiful, and the morning stiffness was considerably reduced to about the first 2 minutes of driving, which seems acceptable to me.
However, after 40,000 km on the Redline mix in 1 year, the morning stiffness is starting to return, as is a slight grind on occasion from 1st to 2nd. Warm shifting is still 100% perfect, and downshifting is still fine as well. Is it possible that the fluid needs replacing already?
This brings me to my next question... The Redline mixture worked beautifully, and I would not hesitate to put the same mix in there again. However, I've heard so many great things about SF MTL-P fluid for this tranny, and I'm wondering if it will perform even better than the Redline mix. I'm in Toronto, so the weather can range from -40 C in the coldest of the winter to +40 C in the hottest of the summer.
What are your opinions on the matter? Thanks for all your help in advance!
