Quote:
Stock Tire - 185/65R15 >Search Tires Tire 1 - 195/60R15 >Search Tires
Section Width: 7.28 in 185 mm
Section Width: 7.67 in 195 mm
Overall Diameter: 24.46 in 621.28 mm
Overall Diameter: 24.21 in 614.93 mm
Sidewall Height: 4.73 in 120.14 mm
Sidewall Height: 4.60 in 116.84 mm
Radius: 12.23 in 310.64 mm
Radius: 12.10 in 307.34 mm
Whoa. Don't go overboard with the precision. The section width of a 185/65-15 tire is 185 +/- 5mm, and the aspect ratio of a 185/65-15 tire is 65 +/- 2.5, with both of those measurements valid only when the tire is mounted on a rim exactly the same width as the "measuring rim."
All tire sizes are specified in section widths ending in -5, so a tire with an "actual" section width of 180.1mm is a "185" tire, as is one with an "actual" section width of 189.9mm.
Similarly, the aspect ratio (distance from rim to outer circumference of unloaded tire, divided by section width) is specified in multiples of 5, so the granularity is +/- 2.5: a tire with an "actual" ratio of 62.6 is a 65-series tire, as is one with an "actual" ratio of 67.4.
So a "185/65" tire could be a 180.1/62.6 tire, with a sidewall height of 112.74mm or it just as easily could be a 189.9/67.4 tire with a sidewall height of 128.00mm.
Moreover, apart from the granularity indicated above, if a tire is mounted on a rim one inch (25.4mm) narrower or wider than the manufacturer's specified measuring rim, the section width will be decreased or increased by about 10mm, respectively.
So take those handy tire size calculators (or your desktop calculator's readouts) with a grain of salt.
