The Bike is well broken-in (I bought it used and it was raced twice) and I just put a new clutch in cause it was slipping. Well, previous bikes I have owned used Gear Oil and Motor Oil, this one only take Motor Oil (I didn't realize this at first). Well I drained the oil and put the new clutch and filter in, but then I added Transmission fluid (Thats what I was used to), but I began to question the fact that there was only one place to put oil in (I don't have an owners manual). So here comes the question...I put the Maxima 85w in it. Can I just drain it and run a regular motor oil in it without replacing the filter again? The bike has not been started since the change. Also, what is recommended for use in this? I am about to take a trip to the Sand Dune(Dumont to be exact) and don't plan on changing the oil the entire weekend. Thank you guys for the help.
