20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
05/26/16 03:48 AM
new castrol edge high mileage synthetic
by hiflo
05/26/16 03:32 AM
Just an interesting question
by southernjeeper
05/26/16 01:52 AM
Value power Walmart battery acid flying out
by bbhero
05/26/16 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
05/25/16 10:35 PM
Steak-House Burgers
by sleddriver
05/25/16 09:53 PM
Got into an accident.
by bdcardinal
05/25/16 09:42 PM
Its coming here more and more
by CourierDriver
05/25/16 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
05/25/16 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
05/25/16 08:21 PM
Toolbox - Pliers
by greasegunn
05/25/16 08:09 PM
ProSelect Oil Filter????
by qwerty1234
05/25/16 08:05 PM
jerryg, 1971tr350, Mak712, Lex4TDI4Life, cdub76
57988 Registered Users
32 registered (chriscpmtmp, Boomer, alcyon, BigD1, bourne, 4 invisible), 655 Guests and 333 Spiders online.
57988 Members
66 Forums
249414 Topics
Page 1 of 4 1 2 3 4 >
#753054 - 10/23/06 07:51 AM Cleaning a PCV valve?
Shaman Offline
Loc: Frankfort, Kentucky
So, I was told it is not really possible to get another PCV valve from anywhere for my car. It's the Japanese way. WHat should I do to clean it up? Just run some carb cleaner throug h it, soak it in kersone, compressed air? I can hear it when I shake it, but it's on an ARX clean, and I want to make sure that the PCV isn't going to cause me any problems.
#753055 - 10/23/06 07:57 AM Re: Cleaning a PCV valve? [Re: Shaman]
ewetho Offline
Loc: Kankakee, IL
Carb clean should do. What used to clean one today at work. Bit of oil gunk and cleaned up fine.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#753056 - 10/23/06 08:22 AM Re: Cleaning a PCV valve? [Re: ewetho]
Dark Jedi Offline
Loc: virginia
what kinda car is it? if it rattles when you shake it. then its fine.
#753057 - 10/23/06 04:28 PM Re: Cleaning a PCV valve? [Re: Dark Jedi]
toocrazy2yoo Offline
Loc: Herndon, Virginia
Shaman, why not just go to the stealer and buy one? I don't like them much either, but you lose your pcv function, you get SUCH a mess. I suppose there are things that mess up an engine worse if they fail, but the PCV has to be up there..
#753058 - 10/23/06 06:11 PM Re: Cleaning a PCV valve? [Re: toocrazy2yoo]
car_junkie_moron Offline
Loc: Fort Worth, TX
if it is a toyota camry? the valve is 8 buck and mo**** f***** gormet for that is also 8 bucks. I just changed it last weekend. I had to because I broke both. BTW I had to take valve cover off to take out gromet as it fell inside.
#753059 - 10/23/06 06:12 PM Re: Cleaning a PCV valve? [Re: car_junkie_moron]
Loc: Fort Worth, TX
gromet not gormet
#753060 - 10/23/06 06:32 PM Re: Cleaning a PCV valve? [Re: car_junkie_moron]
Shaman Offline
It's a Mazda AZ Wagon. I went to the Mazda dealership where the car was purchased. I was told they did not have them. I was also told that it would be very difficult to get one. I will try the Suzuki dealership and see if it will help me out this weekend.
Edited by Shaman (10/23/06 06:34 PM)
#753061 - 10/23/06 08:00 PM Re: Cleaning a PCV valve? [Re: Shaman]
Matt_S Offline
Loc: Metro Detroit
I'd use brake cleaner myself. It's a stronger solvent than carb cleaner and evaporates cleanly.
Whoever said 'nothings impossible' never tried to nail jell-o to a tree.
#753062 - 10/23/06 10:25 PM Re: Cleaning a PCV valve? [Re: Matt_S]
Quest Offline
Loc: beaver land EH?
I use throttle body cleaner that is safe for teflon based TB coating/shaft bushings. CRC (or in Japan it goes by the name KURE, CRC subsidiary in Japan) sells them and they are O2 sensor safe.
Just did a PCV valve cleaning job last weekend on my dad's 7th gen civic (those darn PCV valves are $$$). with 110,000kms on the clock and mostly 5W20/5W30 dino oil with LC, there's a light brown coating on the PCV valve body/intake part. A couple of spray bursts and then soaked for 5 mins before spray-rinse the PCV valve, it's now good as new.
Did the same thing to my wifey's Camry Vee6 (3VZ-FE) PCV valve and same thing: a light coating which came off quickly with a couple of quick CRC spray bursts.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#753063 - 10/23/06 11:06 PM Re: Cleaning a PCV valve? [Re: Quest]
97 GTP Offline
Loc: LI, NY
If it rattles when shaking it's fine. You can clean it in a container and gasoline. That always worked for me it the past.
#753064 - 10/24/06 05:51 AM Re: Cleaning a PCV valve? [Re: 97 GTP]
Shaman Offline
Thanks guys, I am just trying to eliminate any cause of the sludge buildup aside from lack of oil changes.
#753065 - 10/24/06 06:00 AM Re: Cleaning a PCV valve? [Re: Shaman]
Shaman Offline
Quest, I have three different cans of Kure right now. Electronics, Clean-a-carb, and Foaming Engine Spray. i bought the electronics stuff when i was going to clean the MAF on my MS-8 that turned out to be a geriatic looking mute of some kind.
I do have a question about colors though. I heard that red has chlorinated propellant and the green doesn't. I haven't really seen any green cans. Is there another way of identifying the difference.
Edited by Shaman (10/24/06 06:06 AM)
#753066 - 10/26/06 08:43 PM Re: Cleaning a PCV valve? [Re: Dark Jedi]
blupupher Offline
Loc: Katy, Republic of Texas
Not always. there is a spring in some that can wear out and a groove can form in others keeping it from sliding properly.
2002 Ford F-150: Next-Gen 5w-20, Carquest Red Filter, 6 Month/3000 mile OCI
2012 Scion xB: Pennzoil Platinum 5w-20, Wix filter, 6 month/5000 mile OCI
#753067 - 10/26/06 09:02 PM Re: Cleaning a PCV valve? [Re: Dark Jedi]
BuzzCut Offline
Loc: noneyabeezwax
The one in my truck is a fixed orifice with no internal parts. 97 GMC 5.7
#753068 - 10/27/06 08:07 AM Re: Cleaning a PCV valve? [Re: BuzzCut]
Quest Offline
Shaman-
Yeah, I tend to concur with your understanding that red CRC can may come with chlorinated propellent, whereas the green can maybe a bit better for the environment.
My can of CRC throttle body cleaner comes in a red can.
I don't think that it really matters when it comes to cleaning effect for both of them colours seem to work just fine. I would, however, question the sensitivity of the cleaning chemicals used in the specific job knowing that there were some throttle body cleaner in that past that were so strong they would eat into the teflon bushings or coating s or similar, or cause extreme O-ring swelling due to the solvent it used within.
If you can get someone to send a message to KURE asking for the clarification RE: green vs red can, that would be great. Also: given the year/mileage you may have on your AZ wagon, I would seriously consider looking into replacing PCV valve and also give the throttle body a nice cleaning. I recently cleaned my wifey's Vee6 camry throttle body and that helps in restoring the "peppiness" during sudden throttle plate opening, no more jerking off kinda sensation.
Good luck on your AZ wagon. I always love those small K-cars particularly Suzuki Wagon-R, Cappuccino and also some small Dihatsu 660CC delivery vans. Oh how I wish I can own one of those here in Canada (it would be a blast though)
*grin*
