Some more info on Soot from Manns on the web...
Soot particles are spherical in shape and 98 percent carbon by weight. They
are a very small size of around 0.03 microns, but they often agglomerate to
form larger particles. Although the majority of soot produced during
combustion exits through the exhaust, some passes through the rings of the
combustion chamber and enters the engine oil. As long as these soot
particles remain suspended in the oil and are not allowed to agglomerate,
they pose little risk to engine parts. It is up to the motor oil’s
dispersants to keep soot particles dispersed. However, in high soot
conditions, dispersants can become quickly depleted.
High soot load conditions lead to loss of oil dispersancy as an oil’s
dispersant additives are consumed. As dispersancy is lost, soot particles
agglomerate and form larger particles that build up on engine surfaces.
This soot and sludge eventually impedes oil flow, and it can also form on
oil filters, blocking oil flow and allowing dirty oil into the engine. In
addition, high soot levels within a motor oil increase its viscosity,
further impeding oil flow and increasing engine wear. Anti-wear additive
performance is also affected in high soot conditions as additives are
gradually removed from the oil by adsorption to soot particles, leading to
increased wear and premature engine failure.
Another negative effect of high soot conditions is the formation of carbon
particles on the piston ring grooves, causing degradation of the oil seal
between the ring and cylinder line and abrading the ring and liner. As the
gap between the ring and liner increases, combustion byproducts such as
gases and unburned fuels blow into the crankcase, a problem known as
blowby, eventually causing expanding gases to lose ability to push the
piston down and generate the power necessary to propel the vehicle.
Horsepower is lost and fuel efficiency decreases. Ring sticking and poor
heat transfer from the piston to the cylinder wall can also result. Its like cancer if it gets away from you
