I tried to buy some for a Taurus, but after calling back to schedule an installation from a local dealer they were already back ordered in the Portland area. Costco only had one set of Michelin X Ice left in the size that I needed, but I prefer studded. I tried to install a set of 15in Hakkas on 15in steel rims on our car which has 16in wheels, the diameter was the same, they were a litle narrower, load range was good, I suggested a trail fit of the rims but the dealer said that they would work fine per his catalog, and they didn't fit. This was after ordering the tires the day before, waiting for the truck to get thru the snowed in passes, telling the guys that they could do our car last. After some groans, subdued words not suitable for G rated movies, we ended up putting on some slightly wider and very slightly shorter Hakkas on the OEM rims. They're more expensive tires than I wanted but they have 2mm more tread depth than the other Hakkas, I got free studs as they forgot to include them in the quote, but at least we're done with the seasonal winter tire circus. Well, not quite as I still need to get a set of winter rims before the season is done.
