First time poster here, thanks in advance for your time and opinions.
I have a 2001 GMC Duramax truck that had the injectors fail and fill the motor with deisel fuel to the point where it was blowing out of the fill tube. There is a GM service bulliten that was issued that says they have extended the warranty on teh injectors to 200,000 miles and 10 years so the local dealer replaced them under warranty. I told them at that time I didn't think that running deisel fuel inside that motor had done it any good and that the whole motor was suspect in my opinion and was told that "deisel contains some oil so it won't damage anything". I got 2144 miles before a bearing spun and now my motor is trashed and they are telling me that the area rep is denying my warranty coverage because the truck is out of the official 100,000 mile 5 year warranty by 9 months. My point is that the injector failure flooded the engine with solvent, basically, and washed all oil away from the contact areas which caused the failure and the mechanic who is working on it at the local dealership agrees with me completely. I'm looking at $15,600 to get it replaced. I was hoping for some expert opinions on the lubricating properties of deisel fuel as an oil substitute. I'm no expert but I suspect that deisel is not really acceptable as an engine lubricant, and I suspect that the oil pump would not pump it as the viscosity is so low. Any help/tips/advice/pointers towards anything printed that says DO NOT ADD DEISEL FUEL TO YOUR ENGINE, IT WILL DAMAGE IT would be greatly appreciated as the motor is torn apart as I type this and they are awaiting the new engine.
