I work at a truck shop and everytime a truck comes in for a service we air the tires.
and they are usually about 5 pounds low, and some trucks come in weekly
Nope, exactly the opposite in my case.Quote:
For you guys that max out to the sidewall psi......
Don't you see your tires wearing BIG TIME in the middle of the tread? I inflated my OEM Continentals to 37 (7 over Ford recommended) and you could definitely see the middle part of the tread worn down significantly on all 4 tires.
Quote:
It is unfortunate that you don't have the Nitto's any more to verify this, but the maximum inflation pressure is not listed on the sidewall. What it said was something like: "Max Load XXXX at 35 psi."
Quote:
More pressure (over 32lbs) means less wet traction.
