2002 Ford Explorer 4.6L V8.
81,502 total miles.
Wife's daily driver. Around town, suburban driving.
PureOne oil filter
Air filter changed halfway through the OCI.
1 quart of makeup oil over the OCI.
This Pennzoil Platinum 5W-20 was in for 8,002 miles from 6/5/06- 10/4/06. The previous UOA (a year and a half ago) was on Mobil 1 Extended Performance, same driving conditions, 9,000 miles. This is the third run on PP.
OCI 8002 mi(PP)/9000 mi(M1EP)
Total mi 81,502 mi/59,754/Universal Averages
Aluminum 78/3/3
Chromium 0/1/1
Iron 11/10/14
Copper 12/9/5
Lead 0/0/1
Tin 0/1/0
Moly 53/97/55
Nickel 0/0/1
Manganese 1/0/1
Silver 0/0/0
Titanium 0/0/0
Potassium 2/0/1
Boron 2/57/55
Silicon 29/21/15
Sodium 22/113/7
Calcium 2615/2247/2148
Magnesium 14/11/158
Phos 679/652/731
Zinc 852/873/882
Barium 0/1/2
SUS Visc. 58.3/58.1
Flash Pt. 385/410
Fuel Antifreeze 0/0
Water 0.0/0
Insolubles 0.4/0.3
TBN 2.3/2.6
Blackstone:
Aluminum, copper, and silicon all increased significantly here. Aluminum was the worst and is high enough to think a major problem is developing at the bearings. It can also come from the pistons, though if you had a problem there we would have expected to see high chrome (rings) and iron (cylinders). Copper is also a bearing metal. If this engine has recently had any work done to it, then that may explain all of these readings. If not, we suggest checking your air filter and resample in 2,000 miles. The TBN was still okay at 2.3, so the oil itself still has active additive left.
My comments:
I don't like this one a bit.
Could the high metals possibly be from the timing chain? I do hear a bit of noise the front of the engine. Sounds sort of like a belt tensioner. The motor runs great, though. Smooth as silk and strong.
HELP!
81,502 total miles.
PureOne oil filter
Aluminum 78/3/3
Chromium 0/1/1
Iron 11/10/14
Copper 12/9/5
Lead 0/0/1
Tin 0/1/0
Moly 53/97/55
Nickel 0/0/1
Manganese 1/0/1
Silver 0/0/0
Titanium 0/0/0
Potassium 2/0/1
Boron 2/57/55
Silicon 29/21/15
Sodium 22/113/7
Magnesium 14/11/158
Phos 679/652/731
Zinc 852/873/882
Barium 0/1/2
SUS Visc. 58.3/58.1
Flash Pt. 385/410
Fuel Antifreeze 0/0
Water 0.0/0
Insolubles 0.4/0.3
TBN 2.3/2.6
Blackstone:
My comments:
HELP!
