I have a 27' Fountain with a 502 Mag. It has a little over 100 hours since a rebuild (rings / bearings / valve job / turned crank) last summer. I've been running the recommended quicksilver 25w40 since that time, with oil changes on a 20-30 hour interval. Engine has forged pistons, i get a little slap when cold. When i run it hard, i get some blowby and burn some oil. If i drive like an old man, i don't burn any. I haven't done an oil analysis yet, i'm still working on the logistics of getting a good sample out without contaminating it.
Is the quicksilver the best oil I can run? Is there another oil that will give me less blowby and oil consumption, and/or last longer? I'm open to trying synthetics, or other more expensive oils (not that quicksilver is cheap) if it means longer intervals or less blow-by. Is it important to stay with 25w40, or would a slightly different viscosity, or a straight-weight oil be advantageous? I run from April through October in MI, so the engine sees start-up temps from the low 40's to the high 90's.
Other question is oil temp. I have an oil temp gauge, it hasn't gotten past 160 all summer. Most times when i'm running, it will barely get to 140 (minimum reading on gauge). Is this bad? I know I don't want to run the oil too hot, are there consequences to running it too cold?
Thanks, and sorry if i'm asking the "same old questions". I still have some reading to do.
