Subject line states my question. What factors at altitude can have an effect on mpg?
Quote:
No, No, No.
You lose about 3% of your vehicle's horsepower for every 1000 foot in elevation.
Says who? You listed several valid points about oxygen content and then followed up with an unsuported (and unsupportable) slew of personal opinions based on your personal opinion. Power loss, yes. Fuel useage at a given achievable speed at high altitude on flat terrain will be as good as at sea level. The limiting factors will be the maximum achievable speed at a given altitude and the achievable acceleration rate at a given altitude. Older deisel engines with no way to moderate fuel useage according to oxygen content smoked like the dickens at high altitude. That was unburned fuel curling out the exhaust pipe, no question - the fuel injection pumps had little or no provision for the amount of fuel injected. Those that did often required operator intervention to flip a two-position fuel cutoff lever (at least that was the arrangement on my '75 Mercedes-Benz 300D 5-cyl diesel car - I believe later models had an aneroid arrangement that accomplished that automatically.). But even naturally aspirated gasoline engines with modern fuel control systems will be virtually as clean and fuel efficient at altitude at any speed above idle as at sea level.Quote:
Yes, the higher the altitude the worse your gas mileage. The higher the altitude the lower the oxygen content of the air... ... That's why at extreme altitudes you have to wear a oxygen mask so you don't pass out. Now, in a modern vehicle controled by a computer with oxygen sensors it can counteract this to a point. But no amount of injector pulse width adjustment will make up for extreme oxygen depletion completly.
Quote:
Modern EFI will compensate for altitude by using an HAC sensor if it's an L type system. A D type using an MAP doesn't need one. Strickly speaking the O2 content in the atmosphere is the same from sea level to space. It's the reduction in pressure that causes a problem. It's true that parasitic drag decreases with altitude though.
Quote:
Yes, of course. My point was the level of O2 remains the same at appx 21% from sea level on up. Picture a cubic foot box of ISA (international standard atmospher, 29.92 in'hg @ 59 F). Let's say it has 21 green O2 marbles and 79 blue (N2) ones. We'll ignore the trace gases. As the box is raised in altitude the space between the green marbles spreads out but the number remain the same. It's this that results in less O2 being "inhaled" for a given volume by whatever is doing the inhaling.
Quote:
Quickbeam, I like the analogy that you have posted for us. It provides a simple concept for visualizing the make-up of less dense air.
