I bought a jug of Toyota Pink Coolant about a year ago but never used it - I haven't even opened it. What is the general shelf life of coolant? Is this stuff still good?
I currently have green coolant of some sort in my car. How can I be sure that I drain everything out before I put the pink coolant?
My plan is to set the heater control to high, drain the radaitor, and the block. Put a hose to the radiator and engine block until the water drains clear. Ensure that both are drained and that the drains are sealed. Pour 1 gal pink coolant into the radiator. Pour about 3-3.5 qt of distilled water. Cooling system has a capacity of about 7.3 US qts IIRC.
Will this work?
Will this work?
