Brother passed away this morning
by oilboy123
0 seconds ago
Changed oil tonight - what a fine evening
by pacem
10 minutes 38 seconds ago
Interesting observation on Ultra
by RusskiBoSS
Today at 08:48 PM
2009 Honda Civic Cooling fan running continuously
by Doog
Today at 08:31 PM
adhesive for pea gravel?
by xfactor9
Today at 08:19 PM
Micro guard Gl14609 150 hours
by robo339
Today at 08:02 PM
walking thru a Harbor Freight is better than sex
by turtlevette
Today at 07:58 PM
'14 Durango 3.6L, PUP 5w20, 7.5k, TBN/TAN
by Mantooth
Today at 06:59 PM
Advice: Odyssey or Sienna?
by Barwich
Today at 06:43 PM
Any HR specialists out there?
by bustednutz
Today at 06:23 PM
Jawa 350/360 (two-stroke) motor oil
by volodymyr
Today at 05:52 PM
Red Line 20W60 Synth. 1k Miles '13 KTM DUKE 690
by albertdi
Today at 05:49 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
92 registered (66chevelle, 2015_PSD, 1977c10phxdriver, 2010Civic, 4WD, 2009Edge, 7 invisible), 1500 Guests and 100 Spiders online.
57973 Members
66 Forums
249368 Topics
#728610 - 02/12/06 03:27 AM Oil consumption after changing oil brands
Rudolph Diesel Offline
Loc: Chisago City Mn
I own a 2005 Passat TDI and have been using Castrol TXT 505.01. I am about to switch to Elf 506.01 and am wondering, can I expect oil consumption with the new oil. The car at this time does not use any oil. The current mileage is at 23,000 miles. Any feedback is helpful and am new to this website and find it to be very helpful and has a solid referance fom many other websites.
#728611 - 02/14/06 09:52 PM Re: Oil consumption after changing oil brands
m2200b Offline
Loc: Alamo, CA
I'd repost with ELF as your title since you really are asking will ELF 506.01 cause consumption and you'll be lucky to find any ELF users even if it's in the title.
#728612 - 02/15/06 12:41 AM Re: Oil consumption after changing oil brands
moribundman Offline
None, nada, zip, zilch, gar nix? That's scary. [Razz]
I'd expect oil consumption to be higher with a VW 506.01 oil compared to a VW 505.01 oil. I'm sure you know that VW 506.01 is only an option for engines that are properly equipped for oil with a lowered high temperature viscosity.
http://photobucket.com/albums/y108/moribundman/vw_oil.jpg
#728613 - 03/20/06 11:23 AM Re: Oil consumption after changing oil brands
Ken2 Offline
Loc: Washington St.
There are time when switching oil can result in high oil consumption for one to three oil drain intervals. I've heard that the chemistry of the different oils might be the cause.
Ken
#728614 - 04/19/06 09:29 AM Re: Oil consumption after changing oil brands
MolaKule Offline
Loc: Iowegia - USA
You're not dreaming.
Every time we switch proprietary oils for testing, the 4-cycl. engine will lose about 8 ounces up to about 2.5 miles and then AFTER top-of, it will never use any more.
In our air-cooled test engines, it will lose about a half-ounce for the first 8 hours then never lose anymore after top-off until the end of the test.
My theory is that the new oil's detergency is cleaning things out, the engine then gets the new oil into it's rings, and then the oil thickens as it oxidizes slightly, sealing the combustion chamber.
I also believe the lighter hydrocarbon components of previous crud left behind is getting burnt-off or cooked out as well.
#728615 - 04/19/06 09:40 AM Re: Oil consumption after changing oil brands
JHZR2 Offline
Loc: New Jersey
Increased consumption for up to 10k miles has been known to occur when switching to M1 from HDEO in the older MB diesel communities. This is due to use, not due to leaking.
Some get it, some dont... For some it lasts a long while, others, just an OCI or two.
I agree with Mola's findings.
JMH
