Wondering.
and many of those "Motorcycle oils" are nothing more than relabeled cans of car oil with a sprinkling of something that is irrelevent...Motorcycle oil is a good name for a car oil that you want to sell for a couple more dollars a quart...quote:
Originally posted by DeaconBlue:
Motorcycle oils tends to have a lot of additives in them to help them better work with the wet clutch trany setups and to meet the demands of a high load, high revving air cooled engine. These additives are used in a higher concentration levels than is typically found in SL rated automotive oils and in fact can be toxic to catalytic converters. These additives also tend to be the ones that have been removed for the most part from the newer SM rated automotive oils.
For those reasons, I would recommend that you use the correct weight and rated motorcycle oil in your motorcycle.
