So which would you prefer? Which would best run year round in this engine? Both have identical approvals recommended for the 1.8T(vw 502.00, ACEA A3, SL).
M1 is a superb syn product indeed. However, I've heard the same from users in Vortex & CB5/PassatWorld about some noise and consumptions in the 1.8T vs other comparable syns.quote:
Originally posted by Dr. T:
Overall, M-1 oils produce more noise and have more consumption than other brands. I also found greater coefficient of friction with their lubes.
Can you confirm this, AJ?quote:
Originally posted by Audi Junkie:
GC is 1.8t Factory-Fill in Gryor, end of story.
This would be consistent with my VWoA telecon, in which I was told that the VW-brand oil generally used by dealers in the U.S. is Castrol. I am using Mobil 1 0W-40 because it is readily available, and because I BELIEVE it to be virtually as good as anything else on the VW502 list.quote:
quote:
Originally posted by John_E:
This would be consistent with my VWoA telecon, in which I was told that the VW-brand oil generally used by dealers in the U.S. is Castrol. I am using Mobil 1 0W-40 because it is readily available, and because I BELIEVE it to be virtually as good as anything else on the VW502 list.Do you notice any oil consumption w/ M1 0w40? Noisy valvetrain?
I was told before that Castrol is the bulk dealer oil of choice. Frankly, I don't care what they use...after what(crap turbo oil) they did put in our engines before...not even then, not even now.
