Hello everyone,
This is the second UOA on my 2002 Honda Odyssey's transmission. Those of you familiar with this model know that this transmission has a terrible reputation - with complete failure as early as less than 10K miles, and failures between 30-50K miles common. I have indeed been experiencing some rough shifting, and my wife claims it has slipped on the 2-3 shift on a couple of occasions, although I haven't experienced this myself yet. Note that this Odyssey has the optional transmission cooler installed on it. The most recent numbers are on the right side.
Date of Sample: 4/3/2004, 12/30/2004
Miles on Vehicle: 29,941, 40,430
Miles on oil: 29,941, 10,430
Iron: 95, 31
Chromium: 1, Nickel: Aluminum: 98*, 34
Lead: 6, Copper: 15, 6
Tin: 1, Silver: Titanium: Silicon: 15, 8
Boron: 305, 341
Sodium: 10, 3
Potassium: Molybdenum: Phosphorus: 18, 21
Zinc: 333, 413
Calcium: 325, 261
Barium: 12, Magnesium: 187, 429
Antimony: Vanadium:
Oil added: 0.00, 0.00
Water, %Vol: VIS CS 40C: 24.7, 27.7
TAN: 1.35, 1.07
Comments from the lab: Analysis indicates conditions requiring close monitoring. Aluminum may indicate torque converter or pump wear. Material may be partly residual from previous levels. Material may be from oxides. Check for rough shifting, unusual noise or vibration, and excessive metal in the filters or sump. Resample at 1/2 normal interval. Note that after the first UOA on 4/3/2004, I thoroughly flushed the transmission, replacing it with Genuine Honda ATF-Z1. I ran 18 quarts through the transmission - It took several hours. I did not replace the filter, as it appears difficult to get to, on top of the engine but underneath the plastic shroud. I'm not sure what to make of the statement "Material may be from Oxides". Does this mean the ATF may have overheated? I think this is very unlikely, given that I have an auxilliary ATF cooler, and the TAN level is only 1.07. I occasionally tow a small 4x6 trailer, but only for a few miles at a time [moving lawn mowers between my house and a storage facility]
Comments?
Iron: 95, 31
Boron: 305, 341
Sodium: 10, 3
Zinc: 333, 413
Calcium: 325, 261
Antimony: Vanadium:
TAN: 1.35, 1.07
Comments?
